It is currently Mon Jul 21, 2025 2:42 pm
PostPosted: Sat Aug 12, 2023 7:02 pm
Last Name: Haney
City: Sugar Land (Houston)
Zip/Postal Code: 77479
I've seen and heard mahogany tops on guitars. What are some other hardwoods make good sounding tops?
PostPosted: Sat Aug 12, 2023 7:27 pm
Koa, walnut, khaya, sapele, primavera, I’ve seen but not heard ovangkol and now even rosewood. I’m sure there’s more…
These users thanked the author meddlingfool for the post: Ed Haney (Sat Aug 12, 2023 7:33 pm)
PostPosted: Sat Aug 12, 2023 7:33 pm
For a sound somewhere in between spruce and mahogany you might try American sassafras (Sassafras albidum). It falls between spruce and mahogany in weight and hardness and is reasonably stiff. American Chestnut is a similar wood I have used for dulcimers which might also work for guitars.
These users thanked the author Clay S. for the post (total 3): Kbore (Mon Aug 14, 2023 12:26 pm) • Pmaj7 (Sun Aug 13, 2023 1:28 pm) • Ed Haney (Sat Aug 12, 2023 7:49 pm)
PostPosted: Sat Aug 12, 2023 8:27 pm
Pretty!
These users thanked the author meddlingfool for the post: Clay S. (Sat Aug 12, 2023 9:04 pm)
PostPosted: Sat Aug 12, 2023 8:28 pm
Last Name: Kincheloe
Spanish cedar, butternut and catalpa would probably be good. Maybe sweetgum, black cherry and black limba. The smaller the guitar, the less weight matters.
PostPosted: Sun Aug 13, 2023 11:21 am
I've never used Limba myself, but have seen guitars and ukes with it as a top wood.
It's similar in weight and stiffness to Mahogany.
These users thanked the author Colin North for the post: Ed Haney (Sun Aug 13, 2023 11:32 am)
PostPosted: Sun Aug 13, 2023 12:11 pm
First name: Zac
Last Name: Stout
City: Floyd
State: VA
Zip/Postal Code: 24091
I built a Black Limba weissenborn last year and can confirm it makes an excellent top wood. I’ll definitely be using it again.
These users thanked the author Zac Stout for the post (total 2): bcombs510 (Sun Aug 13, 2023 1:15 pm) • DennisK (Sun Aug 13, 2023 12:23 pm)
PostPosted: Sun Aug 13, 2023 12:33 pm
First name: David
City: Napa
Zip/Postal Code: 94558
Its more about the quality and the milling of the wood then a certain species. Check out a book called Understanding Wood this should be required reading for all Luthiers.
These users thanked the author dofthesea for the post: Pmaj7 (Sun Aug 13, 2023 1:29 pm)
PostPosted: Sun Aug 13, 2023 10:28 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
Balsa and paulownia have been used successfully as top woods for stringed instruments. They're soft and prone to scratching, so they might work better on an archtop than flattop.
Balsa: https://www.youtube.com/watch?v=8wqStD-Wejw
Paulownia: https://www.youtube.com/watch?v=9LOHsrLWgq4
PostPosted: Sun Aug 13, 2023 11:31 pm
First name: Josh
Tasmanian/Australian Blackwood (acacia melanoxylon) has been used successfully by the Maton guitar company here in Australia, as well as many individual luthiers.
Here’s an all-blackwood Maton that I’ve just strung up this morning after a bridge reglue and some bracing repairs.
These users thanked the author joshnothing for the post (total 3): Kbore (Mon Aug 14, 2023 12:27 pm) • Ed Haney (Mon Aug 14, 2023 9:24 am) • Colin North (Mon Aug 14, 2023 3:47 am)
PostPosted: Mon Aug 14, 2023 4:08 pm
It depends on how you define 'good' sound. Denser woods can have a nice timbre, but produce less output. That's why we tend to use softwoods for tops: the long grain stiffness at a given thickness tends to track the density pretty well for softwoods because they all have similar structure. Hardwoods vary more in structure, so they don't follow the same rule. Hardwoods tend to have similar stiffness at a given thickness, but they're often twice as dense as softwoods, so the stiffness to weight of the structure is lower with hardwoods. A hardwood top that's stiff enough that it doesn't fold up too soon will end up weighing about twice as much as a softwood one. It's harder for the strings to push, and makes less sound, particularly in the higher frequency range. Hardwood tops tend to sound 'mellow' or 'sweet' rather than 'bright', and the hardwood ones don't 'carry' as well. Again, they can sound fine, but it depends on what you're after. Keep in mind that 'hardwood' is a botanical definition: balsa is a hardwood that is said to make a loud top that dents really easily...
These users thanked the author Alan Carruth for the post: Clay S. (Tue Aug 15, 2023 7:19 am)
PostPosted: Mon Aug 14, 2023 6:31 pm
First name: Trevor
Last Name: Gore
City: Sydney
Probably time to resuscitate this old thread on how I approached building a koa topped guitar. Australian blackwood would work similarly as they are closely related.
http://www.goreguitars.com.au
These users thanked the author Trevor Gore for the post (total 2): Clay S. (Tue Aug 15, 2023 7:18 am) • Ed Haney (Tue Aug 15, 2023 6:59 am)
PostPosted: Fri Aug 25, 2023 9:13 am
Last Name: Cox
Up into the 1970's, Birch was probably as common as spruce for top wood. I've got a couple old birch boxes, and they can be very good guitars.
These users thanked the author truckjohn for the post: Pmaj7 (Fri Aug 25, 2023 11:42 am)
Users browsing this forum: No registered users and 42 guests
